1994 Jaguar XJS FAULT CODE
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
OSCAR GALLO
MY JAG COMES UP WITH A FAULT CODE OF
FF89 ... THIS IS NOT LISTED IN MY REPAIR MANUAL
IS THIS SOMTHING CRITICAL?
ANY HELP APPRECIATED !
THANKS
May 21, 2009 at 5:34 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated hope this helps ..let me know if you have any more question's !! DTC 89: EVAP CANISTER PURGE CONTROL VALVE Check wiring harness and connectors for intermittent fault. Check EVAP canister purge control valve function. Valve is functional if "click" can be heard or if touch can detect it is functioning properly. Check for faulty PCM.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_717.png
May 21, 2009 at 10:30 PM
