1994 Jaguar XJS Engine Hesitation
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
EPIPHINOUS
Picked up car from recent repair on Engine Mounts. When drove out of shop, engine sputtered and stalled. Engine had been previously perfect and clean. OBD says Fuel system code 12 and then 89. Tried crank sensor and vacuum purge valve. Still not it. Possibly the air flow meter. Awaiting part to substitute. Total lack of compression. Smell of un-fully burnt gas out of exhaust
Highly Puzzling. Can you help?
Dec 19, 2009 at 5:44 AM
DAVE H
  • 13,383 POSTS
replace MAF sensor .. code 12 is mass airflow fault
Jan 10, 2010 at 11:26 AM
