1993 no start condition
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRUCIE
gentlemen,
i've owned this car since 60000 and have never had an issue i couldn't diagnose and ulltimately repair.
this time, though. i am stumped. what i've done thus far is determined that the fuel pump runs when its supposed to and the rail is full and pressurized.
spark is present but weak (yellow and thready). I've replaced the amplifier--no change; then i changed the crank position sensor. while i've changed the coil, resistance across the primary and secondary windihgs apperar normal.
what else could it be??
at the end of my rope in Austin, TX
thanks in advance!!
Aug 17, 2008 at 12:35 PM
DAVE H
  • 13,383 POSTS
Ignition pulses are applied from a separate ignition amplifier to the ignition coil. The ignition coil generates high energy pulses for the spark plugs. The distributor does not have centrifugal or vacuum advance mechanisms. The distributor is only necessary to distribute spark to the proper cylinder.
replace cap and rotor !
Jan 9, 2010 at 10:20 PM
