1993 Jaguar XJS heater core
1993 JAGUAR XJS
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
JTMURDOCK
Where is it and how do I get there, and please don't tell me I have to pull the engine.
Thanks
Aug 19, 2009 at 8:08 AM
IMPALASS
  • 3,112 POSTS
Hello –
Well………….on some cars I think they say, here is a heater core………lets make a car to fit it and build it all around it…………..
Doesn’t look too bad in your case………….I have attached the general info…………I am still looking for some type of pic for you………..doesn’t appear to be any in the manual but will continue to look………wanted to get this to you.
Aug 19, 2009 at 2:57 PM
IMPALASS
  • 3,112 POSTS
Hello –
Hey I have a good idea………….why not this time I put the info with this…………
HEATER CORE
Removal & Installation
1. Disconnect negative battery cable. Drain engine cooling system. Remove left hand console side casing and dash liner. Remove glove box. Remove heater box cover screws. Remove rear heater box panel and move front panel and foam seal out of the way for access.
2. Disconnect heater pipe from heater box. Remove and discard gasket. Disconnect wire from coolant temperature switch. Remove foam pad from pipes and move vacuum hoses out of the way. Remove front heater panel. Disconnect heater hoses from heater core and remove heater core. To install, reverse removal procedure. Ensure new gaskets are used.
Aug 19, 2009 at 2:58 PM
IMPALASS
  • 3,112 POSTS
Hello –
I’m sorry……….there doesn’t seem to be any pics for the heater core or HVAC system for this model……………hope the directions when looking at it are helpful.
I even went into the parts area as sometimes they have a part breakdown………again, no luck
Aug 19, 2009 at 3:05 PM
