Air Conditioning problem
1993 Jaguar XJS 6 cyl Automatic 48,500 miles
Last year A/C worked fine. This year, when I turn the climate control to anything below 72 degrees, the air begins to blow thru the defrost vents. If I set it hotter than 72 degrees, air blows thru face vents. I want the air to always blow thru the face vents. Dealership checked everything including taking off the dash. They could not locate the problem and said I would need to buy/intsall a new "Air Box" (Approx $4000.00).
Aug 10, 2009 at 4:35 PM
