1990 Jaguar XJS gas odor
111,000 MILES • V12 • 2WD • AUTOMATIC
MADHDD
When I use the car and stop ie light, stop sign etc, I notice a strong gas smell. I can also hear gurgling in my gas tank when I shut the engine off. I know it could be a venting issue but where and how do I check?
Dec 29, 2008 at 11:51 PM
DAVE H
  • 13,383 POSTS
XJS
The fuel evaporation system is designed to keep fuel and crankcase vapor from escaping into the atmosphere. The fuel tank venting is designed to ensure vapors are vented through the system even when the vehicle is parked on an inclined surface.
When the fuel tank vapor pressure exceeds a preset limit, the pressure relief valve opens and vapor flows into canister for storage. The purge control valve limits maximum purge airflow rate.
Jan 9, 2010 at 11:31 PM
