1990 Jaguar XJS Coil failure
90,000 MILES • V12 • 2WD • AUTOMATIC
MAGNUSANDTHOR
I go thru 2 coils a year. Seems when I do a lot of stop and start around town driving and it get's extremly hot under the hood a coil fails?
Is heat causing the failue? And if so, can they be relocated to the trunk?
Thanks
Aug 31, 2008 at 10:13 AM
SERVICE WRITER
  • 9,123 POSTS
Things I would suggest is to use an OEM coil, not aftermarket.
Make sure the wires, plugs cap and rotor are good. Weak components can cause a failure to the coil.
Also check wiring in the loom that goes to the coil.
Aug 31, 2008 at 12:30 PM
