1989 Jaguar XJS Horn
53,000 MILES • V12 • 2WD • AUTOMATIC
COLT45CZ75
My horns will not blow. I removed and bench tested them and they work. I removed the Momo button and checked power in the steering column and had 1 volt. I checked the horn button with ohm meter and had trouble making a connection . Is the button done or is it a lack of voltage or both?
Mar 16, 2009 at 10:57 AM
DAVE H
  • 13,383 POSTS
have someone press the horn while you check for voltage at horn connectors ..
Jan 9, 2010 at 11:42 PM
