1989 Jaguar XJS air conditioning switch
80,000 MILES • V12 • 2WD • AUTOMATIC
DEREKJONES
In the manual, it talks about a low pressure switch which cuts off the a/c automatically until reset by a mechanic. Does anyone know where this switch is so i can do this myself, or has anyone else experienced this problem? If you have, please contact me @ pongplaya014@aim.com. Thank you
Jun 8, 2008 at 12:41 PM
DAVE H
  • 13,383 POSTS
A/C COMPRESSOR INOPERATIVE
Defective compressor clutch. Defective super heat switch/thermal fuse. Defective heater coolant thermostat. Defective Ranco thermostat (or evaporator temperature switch). Blown Ranco thermostat in-line 10-amp fuse (in wiring next to thermostat in Brown/Yellow or Pink wire). Defective main relay or no electrical power to main relay.
Jan 9, 2010 at 9:27 PM
