1988 Jaguar XJS ignition switch
MRYAN43
Electrical problem
1988 Jaguar XJS 6 cyl Front Wheel Drive Automatic
I need to refit an ignition switch and am having trouble taking out the old one. It is secured by a circular top bolt and can se no way of removing them. Any ideas ?
Feb 15, 2009 at 10:58 PM
DAVE H
  • 13,383 POSTS
STEERING LOCK & IGNITION SWITCH
Removal
Remove steering wheel, upper and lower steering column covers and combination switch. Disconnect ignition switch harness connectors.
If the shear bolt studs are accessible, use a hacksaw to cut a slot into the exposed studs. Using a screwdriver, remove the studs.
If the shear bolt studs are recessed or hard to reach with a hacksaw, center punch studs. Using a drill bit and a screw extractor, remove studs. Remove steering lock and ignition switch.
Installation
To install, reverse removal procedure. Install new shear bolts. Tighten shear bolts finger tight. Ensure proper operation of steering lock and ignition switch.
Tighten shear bolts until heads break off. Install combination switch, upper and lower steering column covers and steering wheel.
Jan 9, 2010 at 11:37 PM
