1987 Jaguar XJS No power to power windows.
79,335 MILES • V12 • 2WD • AUTOMATIC
HERMAN BRUCE
I suddenly lost power to my power windows, when checking the switches and wiring, I found no power to the wires. if I add current to the main feed wire all windows will work. I don't kow if there is a fuse, circuit breaker, relay or some type of fuseable link in the system and where it is locaded, because I have looked every where; can you help? Thanks Herman.
Dec 11, 2007 at 8:40 AM
MERLIN2021
  • 17,250 POSTS
You should have at least 2 fuses, one under the dash, the other could be a maxi fuse in the under hood fuse block. Also the wires in the door can crack were they pass thru to the interior...were they flex.
Dec 11, 2007 at 8:42 AM
