1986 Jaguar XJS starter replacement
1986 JAGUAR XJS
106,711 MILES • V12 • 2WD • AUTOMATIC
THOMASRMR
Do you know the steps to replace my 1986 jaguar xjs starter
Mar 15, 2010 at 12:40 PM
Sorry no pic available:
Disconnect battery ground cable. Raise and support vehicle.
Remove right exhaust pipe from over-axle pipe forward.
Remove right front catalytic converter assembly for access.
Remove heat shield from starter.
Disconnect starter leads from solenoid.
Loosen starter mounting bolts, then remove starter motor.
Reverse procedure to install.
Mar 15, 2010 at 6:32 PM
