1986 Jaguar XJS Electric Speedometer not working
73,000 MILES • V12 • 2WD • AUTOMATIC
BOB KREHBIEL
Where is the fuse for the spedometer so that I can see if that is my problem. I have replaced the speedometer generator on the transmission and that made no differrence. Nothing is working, except the light.
I sure would appreciate any help of ideas that you could give me.
Bob
Jan 13, 2008 at 11:19 AM
KEN.RUOCCO
I HAD THE SAME PROBLEM,BUT MINE WAS SOLVED BY RE WIRING THE CONNECTIONS TO THE TRANSDUCER SWITCH ON THE GEARBOX.THE FUSE COVERING THE SPEEDO IS #4,BUT IT ALSO COVERS THE BACK-UP LIGHTS,SO IF THESE ARE WORKING ,THE FUSE IS FINE.
May 9, 2008 at 9:03 AM
