Windshield Wipers do not work
JUMPMAN23
V12 two wheel drive automatic 50,000 miles
Hey, the windshield wipers do not work. They worked fine a couple months ago, but after all the snowstorms it does not do anything now. I checked the fuses, and they all seem fine. I do not know if it is a relay or if it could be anything else. Any Ideas?
May 2, 2010 at 6:44 AM
DAVE H
  • 13,383 POSTS
check both fuses (two).check relay and the check wiper switch and wiring.
May 8, 2010 at 8:29 PM
JEEPLADY
V8 two wheel drive automatic 13,000 miles
speedometer works intermittently, horn, windshield wipers do not work at all.
Jan 5, 2017 at 7:20 AM (Merged)
DAVE H
  • 13,383 POSTS
check fuses and replace the speedometer cable.
SAMMIET
windshield wiper do not work.
Jan 5, 2017 at 7:21 AM (Merged)
DAVE H
  • 13,383 POSTS
check the fuse and relay, then the motor is getting power (twelve volts) if power is going to motor then the motor is bad.
DELBERT WORLEY
six cylinder two wheel drive automatic 115,000 miles
the windshield wiper stopped working and the switch to make the steering wheel go up and down stopped working among other things.
DAVE H
  • 13,383 POSTS
start by checking all fuses.
