1985 Jaguar XJS
SHORTIE71588
  • 1985 JAGUAR XJS
  • V12
  • 88,000 MILES
I'll be driving down the highway or any where and my car will just quit. It can run a mile or up to 50 miles before it quits. Fuel filter, coil, ignition amplifier were replaced and problem persists. Replaced the battery and didnt solve the problem. Any idea what it could be?
Thursday, August 20th, 2009 AT 6:44 PM
DAVE H
  • 13,384 POSTS
PICK-UP COIL-TO-RELUCTOR AIR GAP
Normally, air gap will not need resetting unless it has been tampered with. Always use a plastic feeler gauge when checking or setting air gap. See Fig. 2. Gap must be checked at each reluctor tooth.
To check air gap, align reluctor tooth with pole piece of pick-up coil. Insert proper plastic feeler gauge. On XJS, set air gap at.007-.015" (.18-.38 mm). Check gap at each reluctor tooth.
To adjust air gap, loosen pick-up coil mounting screws. Align reluctor tooth with pole piece of pick-up coil. Insert proper feeler gauge and move pick-up coil against gauge. Tighten mounting screws.
Sunday, January 10th, 2010 AT 8:46 AM
