1980 Jaguar XJS How to improve oil pressure?
155,000 MILES • V12 • 2WD • AUTOMATIC
IVANTONI
Hi there,
I am a Jag enthusiast and ive just recently bought an xjs jaguar v12 with about 155,000kms on the clock, the car seems to be running well as far as water cooling as the temperature hangs about the half way mark. However not so sure about oil pressure because after starting the car from cold the oil pressure gauge sits about the half way mark but after about half an hour of driving the oil pressure shows close to the '1' and '0' mark!
As I have just bought this car my question is what are some steps I could take to kerb the low oil pressure? should I just take it to a professional for a good service or is their a more simple solution?
cheers
Sep 19, 2008 at 4:48 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch-abnormal readings could indicate a problem with oil pump/engine bearings/oil galleries/sludges etc
Sep 19, 2008 at 6:04 PM
JACSPEED
if the engine is already warm, to 800-900 rev/minute, low pressure is normal, but accelerating, it must go up.
bye. mark
Jan 5, 2009 at 3:22 AM
  • 75,988 POSTS
Good theory-but when it goes beyond the limit then you have a problem
Jan 5, 2009 at 5:23 AM
