I have a 1997 Supercharged XJR(X300). Until recently it was running fine then one day i was driving along and the car lost power and engine light flashed. Now when i drive along the road and accelerate the engine spluters, the engine light comes on and the car trys to die on me.
The car is lumpy on idle slightly, but revs fine when done slowly. If the accelerater is depressed fast the engine light comes up and the car trys to die. There are no fault codes, i have changed both lambda sensors. However the scanner tells me the car is running very lean all the time at 25-30%.
Jun 11, 2006 at 12:28 AM
