2001 Jaguar XJR engine cranks, then dies
132,000 MILES • V8 • 2WD • AUTOMATIC
MICKEYTUMLIN
My Jag will crank and then die. This happened almost a month ago out of the blue, then suddenly cranked one day, drove for over a month with no problems, and has now done it again. ould it be the crank sensor needs replace? or what?
Jul 27, 2010 at 11:22 AM
JAGTECH360
  • 74 POSTS
Check the air snokel and intake for leaks. Possible mass air flow sensor or a leak in the air intake snorkel. Check the breather tube that goes between the snorkel and valve cover.
Oct 30, 2010 at 3:53 AM
