2000 Jaguar XJR Windsheild Wipers
65,000 MILES • V8 • 2WD • AUTOMATIC
BOSCO7744
It is raining very hard in Northern CA and I used my wipers on high for I'd say maybe 20 minutes as I ran an errand.
I parked the car turned it off and after I came out to go home about 1 hour later the wipers would not work.
If i press the button on the end of the control arm the water shoots out, but the wipers do not move. What Happened?
I did have the fuses checked, and the mechanic said they were okay.
What else can I check or do to try and resolve this problem.
Jan 5, 2008 at 10:04 AM
FSTRANGER302
  • 117 POSTS
[quote:ea4e1ebd31="Bosco7744"]Other Category problem
2000 Jaguar XJR V8 Two Wheel Drive Automatic 65000 miles
What else can I check or do to try and resolve this problem.[/quote:ea4e1ebd31]
hello, have the relays for the wipers there are two. both of them are right next to each other. behind the drivers head light next to the fans. common problem with car. hope this helps. let meknow. rep points apreciated if this helps
Jan 19, 2008 at 5:42 AM
GEORGEJAGUAR
  • 10 POSTS
hi jaguar dealer technician in n calif i would replace both your wiper relays in left front part of engine bay seen this problem before plenty of times
Jul 11, 2008 at 6:52 PM
