2000 Jaguar XJR ASC warning light keeps activating (tractio
77,000 MILES • V8 • 2WD • AUTOMATIC
PAUL1956
got a XKR and the bloody error message - ASC warning light goes on and the motor goes a bit waco? When I turn off TRACTION CONTROL no problem. I just put new tiires on could this be the issue or is it the Jaguar gods turned against me. I am in LA area and find that most mechanics for jags charge a lot and do not do diagnostic work on these cars ONLY deductive repair logic - when the replace enough stuff they usually finally fix the problem. How do i stop the nasty warning and engine traction control error from hitting me up side the head with the fatty british part of the hand??? thanks
Nov 7, 2008 at 5:39 PM
DAVE H
  • 13,383 POSTS
check ABS sensors and hub bearings
Jan 10, 2010 at 12:20 PM
