2000 Jaguar XJR ABS/Traction control failure (engine failsa
72,000 MILES • V8 • 2WD • AUTOMATIC
KAAREANDERSEN
Hello
I have an annoying problem I hope you can help me with.
When the car is cold and I go to reverse, the engine goes in failsafe mode due to ABS/traction control failure.
I have tried replacing the transmission control module with no improvement (borroved from another car).
I think I need to try to replace the ABS/traction control module as well. If this doesn´t eliminate the problem, how do I proceed from there?
Best regards
Kaare
Oct 21, 2008 at 8:35 AM
DAVE H
  • 13,383 POSTS
check ABS sensors and hub bearings
Jan 10, 2010 at 12:18 PM
