1999 Jaguar XJR Battery
LORI DOLAN
Other Category problem
1999 Jaguar XJR V8 50,00 miles
Where can i find the kill switch that disables the battery if i am not using the car for a long period of time
Jan 25, 2008 at 6:07 AM
DISCOSTU24000
  • 37 POSTS
I dont know of any kill switch on this vehicle unless it was installed by an aftermarket company. Just disconnect the negative battery lead and it will stop draining.
P.S. this will reset your clock and radio presets. Also make sure you have the security code for the radio since it may not work when you reconnect the battery without it.
Apr 24, 2008 at 5:34 AM
