1998 Jaguar XJR engine swap
1998 JAGUAR XJR
96,000 MILES • V8 • 2WD • AUTOMATIC
THICKETS1
My 1998 jag Xjr needed a new engine and i got one from damrons used for a 98-99 pulled old engine and installed new/used one and only difference is the Cam Position sensor old engine had one on drivers side. NEw engine has two one each bank. Vehicle almost starts puffs al little but doesnt stay running. ? can i just get a 1999 wiring harness and 99 ecu and will this do it or is there a way to jumper the wires this is going to be daily driver bought it very cheap so give me the best advice rest of car is perfect.
Thanks for anyones time
PS tried starting with Crank position sensor wire to one bank and to the other and then attempted a jumper any help>
Jan 16, 2010 at 6:17 AM
DAVE H
  • 13,384 POSTS
hello .. thanks for the donation .. much appreciated you will need to replace the wiring loom and the ECU I'm afraid, the current ECU is not getting the correct reading's from the engine sensors .. Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_970.png
Jan 16, 2010 at 9:23 AM
THICKETS1
Any one have an idea on what year ecu an wiring loom to aquire? Which year engine begins dual cam position sensors on the xjr. As stated orig 1998 engine has drivers bank as single sensor new engine has one in each bank.
Thanks for help with I'd on which year to find for ecu an loom
Paul
Jan 16, 2010 at 11:02 AM
