1998 Jaguar XJR 1998 Jaguar XJR
1998 JAGUAR XJR
68,000 MILES • V8 • 2WD • AUTOMATIC
JBSYKES
Hi, Have just had to replace the engine on my Jag XJR. Fitted a secondhand one but there is a problem with the second cylinder - spark plug gets sooted up quickly and then runs poorly on tick over - could this be valve seals or is it likely to be piston rings? All other cylinders are fine and engine has only done 68K.
Thanks
Aug 12, 2009 at 12:43 AM
DOCFIXIT
  • 18,828 POSTS
If sooty then it is fuel so injector is leaking possibly. Check comperssion if good then injector cleaning or replacement.
Aug 12, 2009 at 1:15 AM
