1996 Jaguar XJR Noisy water pump
195,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRUCEDIBBEN
Is it a do it your self job to change the water pump on an XJR x300 6 cylinder Jaguar?
Many thanks,
Bruce
Jan 10, 2010 at 5:04 AM
DAVE H
  • 13,383 POSTS
WATER PUMP
Removal & Installation
Disconnect negative battery cable. Drain cooling system. Remove air cleaner assembly. Remove electric cooling fans and radiator fan shroud (if necessary). Remove alternator belt. Remove coolant hoses if necessary. Remove water pump. Clean gasket mating surfaces.
To install water pump, reverse removal procedure. Apply Hylosil 102 sealant to water pump, and install pump. Fill cooling system, and check for leaks.
Jan 16, 2010 at 11:17 PM
BRUCEDIBBEN
Many thanks to Dave for your simple and straight forward explanation.
Bruce from UK
Jan 17, 2010 at 12:08 AM
