Rear Bulb Fail warning - Jaguar XJ8 1998
1998 JAGUAR XJ8
MRRIOLOCO
Receiving a "Rear Bulb Fail" warning when I depress the brake pedal. I replaced the right rear brake bulb as it was not lighting, however it still will not light and I still get the warning. This is for a 1998 Jaguar XJ8 that I am looking to get in shape for sale as I cannot afford it any longer. I believe this has a 4.0 L V8. It is an automatic transmission and has about 75,xxx miles. I wonder if it is a fuse issue or maybe a controller unit. Any suggestions? I really appreciate the help. :D Hope all of the donations keep you guys going!
Aug 20, 2007 at 5:37 AM
2CARPRO JACK
  • 11,533 POSTS
Does that car have seperate sockets for the bulbs or is it a plate that they all plug into? Might have a bad connection in the socket where the bulb plugs into.Make sure the contacts are clean and making a good connection with the bulb
Aug 20, 2007 at 8:50 AM
MRRIOLOCO
It has a plastic plate that 4 bulbs go onto. It has a wired harness that controls the entire board. I will clean the contacts and make sure the prongs are out and not cracked. Is there anything else I should be aware of, or good techniques for cleaning?
Aug 21, 2007 at 4:39 AM
2CARPRO JACK
  • 11,533 POSTS
Small piece of sandpaper or an emery board works good.The problem might be in the board, seen them fail internally before
Aug 21, 2007 at 5:03 AM
