2005 Jaguar XJ8 shifter assy.
LARRY BAER
Interior problem
2005 Jaguar XJ8 V8 Two Wheel Drive Automatic
what do I have to do to remove the center consol so I can remove shifter assy to dry out the switches .Something was spilled on the shifter and will not come out of park. Does jaguar have an o.b.d.2 plug like the us cars do because i have some faults an the dash because i disconnected the batt. I didn't have them untill i did that. I just couldn't get it out of park.
Jan 19, 2010 at 7:59 AM
DAVE H
  • 13,383 POSTS
OBD Data Link Connector....At left side of transmission tunnel
TRANSMISSION SELECTOR LEVER
Removal
Remove the INSTRUMENT PANEL CONSOLE .
Remove the ash tray retaining screws.
Fig. 9: Removing & Installing Ash Tray Retaining Screws
Courtesy of JAGUAR CARS, INC.
Detach the ash tray.
Fig. 10: Removing & Installing Ash Tray
Place the transmission selector lever to the "R" position.
NOTE:Shown with the electric parking brake switch removed for clarity.
Fig. 11: Disconnecting & Connecting Electrical Connector
Disconnect the electrical connector.
Detach the wiring harness bracket.
Reposition the wiring harness.
Fig. 12: Removing Wiring Harness Bracket
Detach the selector lever cable. See Fig. 3.
Detach the transmission selector lever.
Remove the retaining bolts.
Fig. 13: Removing & Installing Selector Lever Retaining Bolts
Disconnect the ignition switch interlock cable.
Detach the ignition switch interlock cable.
Jan 30, 2010 at 10:36 PM
