2004 Jaguar XJ8 shifting problems
70,300 MILES • V8 • 2WD • AUTOMATIC
JAGMAN2004
the car will not shift into the next gear at 40mph. the rpm gauage jumps around tries to shift but have to give it gas to shift
Dec 23, 2008 at 11:21 AM
  • 55,583 POSTS
Hello, two things, is the check engine light on, and did you check the transmission fluid level?
Dec 27, 2008 at 11:14 AM
M DARROW
I am having the exact same problem between 35-45 mph. There are no warning lights on and all fluid levels are fine. My mileage is only 35,000. Any ideas on what to have a mechanic look at?
[quote:2685ed3e48="jagman2004"]Transmission problem
2004 Jaguar XJ8 V8 Two Wheel Drive Automatic 70300 miles
the car will not shift into the next gear at 40mph. the rpm gauage jumps around tries to shift but have to give it gas to shift[/quote:2685ed3e48]
Mar 26, 2009 at 12:26 PM
  • 55,583 POSTS
Have you checked the condition of the fluid? Does it have a burnt smell?
Mar 27, 2009 at 6:01 AM
