2003 Jaguar XJ8 Passenger Door Ajar Warning Light
73,300 MILES • V8 • 2WD • AUTOMATIC
DGIUDICE
My alarm is going off at intermittent times and I'm seeing a 'passenger door ajar' on my dash.
I understand there is a microswitch in the doorlatch, but when I look up for a part to replace it, I'm only seeing the lock actuator or lock module, both of which are $300. Is there a switch (for less) than I can buy and replace in the door that will stop the error messages?
Dave
Mar 22, 2010 at 3:48 AM
DAVE H
  • 13,384 POSTS
you have to replace the latch assembly, the microswitch is internal .. try sprying the latch assembly with a lubricant and opening and closing the door a few times to free off the switch
Mar 23, 2010 at 10:00 AM
