2003 Jaguar XJ8 Noises
2003 JAGUAR XJ8
55,000 MILES • V8 • 2WD • AUTOMATIC
MUSICMAN615
2003 XJ8 when you are driving it sounds like something ratteling under the rear of the car. This only happens when you go over a bump or rough road. They re-shimed the wheel barring and this did no good. Also, there is another noise coming from the right rear that sounds like a tire rubbing on something metal. This happens only sometime and when you let off the gas peddle, sometime it quits and sometime it does not. Just bought this car and the local jag dealer will not even return my calls. Any help will be greatfully appreciated.
Thanks,
W.C. Staley
wcs615@aol.com
Oct 7, 2009 at 9:13 AM
  • 31,937 POSTS
Hi there,
Have the rear shockers checked first check mountings and valving in the shockers, also a call or a letter of complaint to Jag head office will normally get some action going.
Mark (mhpautos)
Oct 7, 2009 at 10:09 AM
