2002 Jaguar XJ8 headlight
40,000 MILES • V8 • 2WD • AUTOMATIC
LEEOMIE
How do I remove the headlight to replace the bulb. I think the piece that holds the bulb can be remove from the back of the lens. I also need a repair manual for this vehicle.
Dec 28, 2008 at 9:36 AM
DAVE H
  • 13,383 POSTS
your local autoparts store will be able to supply a repair manual for the vehicle ..
High Beam Headlamp Bulb
Removal
Open hood and install fender cover.
Release headlamp bulb holder locking tangs and remove holder from headlamp.
CAUTION:If the bulb is to be re-fitted, the glass must not be touched with the bare hand. Failure to observe this caution will result in premature bulb failure
Position bulb holder for access and remove bulb.
Dec 31, 2009 at 10:11 AM
