2001 Jaguar XJ8 How much and what kind of oil? Wheres the f
OTERO713
  • 2001 JAGUAR XJ8
  • V8
  • FWD
  • 126,000 MILES
Hello I was wondering what kind (weight) and how much (capacity) of oil to use. I just did an oil filter change and im not sure what kind of oil and how much to use
and I also need to change my fuel filter do you have an idea where it is?
anthony
Sunday, May 10th, 2009 AT 7:19 PM
DAVE H
  • 13,384 POSTS
10/30 motor oil
FUEL FILTER
NOTE:Removal and installation procedures for fuel filter on XJR, XJ8, XKR and XK8 are not available.
Removal & Installation (S-Type)
Fuel filter is located behind left front wheel splash shield. Release fuel pressure. See FUEL PRESSURE RELEASE. Raise and support front of vehicle. Remove 3 left fender splash shield fasteners. Remove left fender splash shield. Disconnect fuel lines from fuel filter. Remove fuel filter bracket bolt. Remove fuel filter. To install, reverse removal procedure.
Thursday, December 31st, 2009 AT 8:12 PM
