2000 Jaguar XJ8 recalls
120,000 MILES • V8 • FWD • AUTOMATIC
JOJO63
I was wondering if there were any recalls for the 2000 xj8 jag. Also i keep getting warning messages like coolant low, fuel low and ABS Trac not working.
These are false. The coolant levels were full and so was the fuel. Why is it doing this?
Jan 10, 2009 at 11:51 AM
IMPALASS
  • 3,112 POSTS
Hello –
You do have some recalls – I have attached them –
600-03
10/01/2004
Campaign - Engine Breather Scheduled Cleanings
204-S499
08/01/2003
Campaign - Control Arm Bushing Inspection/Replacement
303-S490
02/01/2001
Campaign - S490 Drive Belt Chafing on Mounting Bracket
413-S703
09/01/2000
Recall - S703 Fuel gauge Reads Low
418-S702
08/01/2000
Recall - Insecure Electrical Ground
413-S484
12/01/2001
Recall - S484 Instrument Pack CAN Assembly
The fuel gauge may be reading low due to the fuel gauge recall…………or it may be tied to the Instrument Pack CAN Assembly recall as this has a concern with multiple warning lights.
I would check these out first and if that doesn’t fix your problem then get back with us.
I am not sure if you know, but all you have to do is contact the dealer service department and provide them your VIN. Normally recalls are fixed with no charge.
Jan 10, 2009 at 1:11 PM
