2000 Jaguar XJ8 How to remove the third brake light assembl
23,000 MILES • V8 • 2WD • AUTOMATIC
AUTOGALLERYOFDE
How do you detach the entire hird brake light assembly on a 2000 Jaguar XJ8?
Thank you
Dec 19, 2008 at 6:04 AM
DAVE H
  • 13,383 POSTS
High Mounted Stoplamp
Removal
Remove lamp cover.
Depress two tangs at base of lamp carrier and withdraw cover.
Fig. 42: Removing Lamp Cover
Courtesy of JAGUAR CARS, INC.
Disconnect lamp harness connector.
Fig. 43: Disconnecting Lamp Harness Connector
Remove module.
Release spring clips at each end of lamp lens module and withdraw module from carrier.
Fig. 44: Removing Module
Remove lamp carrier.
Release lamp carrier lower securing tangs.
Slide carrier upwards to release and remove carrier from backlight.
Fig. 45: Removing Lamp Carrier
Installation
Ensure that rubber insulating pads are installed on lamp carrier.
Fig. 46: Installing Lamp Carrier
Install lamp carrier on backlight mountings, ensuring retaining tangs seat correctly.
Fig. 47: Installing Lamp Carrier On Backlight Mountings
Install lamp module.
Slide lamp module into carrier ensuring retaining clips seat correctly.
Fig. 48: Installing Lamp Module
Connect harness connector to lamp assembly.
Fig. 49: Connecting Lamp Assembly Harness Connector
Install cover on lamp ensuring tangs locate correctly in carrier.
Fig. 50: Installing Cover On Lamp
Dec 31, 2009 at 10:00 AM
