1999 XJ8 Vanden Plas - How are the cylinders laid out
1999 JAGUAR XJ8
GKYGRL
I've discovered that my second cylinder is causing problems but am trying to find a diagram (I own a shop manual on CD, but cannot find this information on it) of how the cylinders are laid out.
Can anyone share this information by either a diagram or saying something to the effect of:
"the cylinders on the drivers side are ....." Do they count from the front or the back, etc.
I just need to figure this out.
Thanks,
A jaguar-owner's daughter :D
May 16, 2007 at 3:48 AM
LEE3393
They are numbered (from the drivers seat) from front to rear passenger side first 1-2-3--4 then drivers side 5-6-7-8. Hope this helps. I have attached a diagram.
https://images.2carpros.com/forum/automotive_pictures/82431_Jaguar_Cyl_Firing_Order_1.gif
Jun 28, 2007 at 6:36 AM
GKYGRL
Much appreciated!!!
Jun 28, 2007 at 12:33 PM
LEE3393
You can try replacing the boots on the coils first, that was all mine required. It felt like the car was going to choke down at idle. They had blue/brown spots on them and appeared ok but weren't. Check out the posts on roadfly.com/jaguar/forums you can search for issues. I'm listed as LeeXJ8ducati
Cheers
Jul 15, 2007 at 5:42 PM
