1999 Jaguar XJ8 Won's Start
80,000 MILES • V8 • 2WD • AUTOMATIC
MARYSJAG
Jag was running just fine. Set over night and would not start mid day. Fired up for a few seconds then stalled. Would not re-start.
Spark checks out OK, fuel checks out OK.
Mechnics are stumped.
Happy to donate if I get any answers I can use. I have already paid but still waiting for answer.
Once when this happened I was told that if you put oil in the spark plug holes the Jag engine will rebuild compression and start. It worked before but I would like feed back on this.
Nov 23, 2009 at 9:23 AM
DAVE H
  • 13,383 POSTS
have you actually got no compression ? are there any fault codes stored in the PCM
Jan 4, 2010 at 9:50 PM
HORTO02
I have exactly the same issue and have been told its low compression due to the piston rings wearing. This was from a Jag garage who said they could only replace the engine at over £7,000. They also said that I could just put foot on the accelerator when I turn the car over and it works.
It doesn't like cold starts but as the engine warms and metal expands issue goes away
Mar 9, 2010 at 9:58 PM
