1999 Jaguar XJ8 STABILITY CONTROL FAILURE
71,188 MILES • V8 • 2WD • AUTOMATIC
JAMJAM940
my 1999 xj8 ABS & stability control failure message is on. How do I check The following abs senors,control module,pump and how do I reset the computer to clear the errors? Also recently the check engine indicator can on. what type on code reader do I need to get to read jaguar codes? Also I would like to know if the brake switch could be the source of my problem?
THANKS!!
JAM
Feb 27, 2010 at 6:16 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated Most OBDII code scanners will link to your vehicle and supply and delete powertrain (engine/transmission) fault codes .. very few handhald scanner's will diagnose and delete ABS fault's .. you will need a shop to diagnose the ABS codes or autozone/aamco will scan cars for free ... Without knowing the actual codes your car is giving it is impossible for me to give you repair information as we would be replacing parts untill we got it right, at your expense ? get your cars full fault codes (P1234 etc.) and repost for a better diagnosis of the fault and repair procedures. The brake light switch supply's power to both ABS control module and Suspension control module ... so it is possible the switch is causing your faults .. A scan of the car and codes givin will let us know where the fault lies ? Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_1011.png
Feb 27, 2010 at 11:18 PM
