1999 Jaguar XJ8 headlight switch
73,234 MILES • V8 • 2WD • AUTOMATIC
JOHN_QUICKLY
The head light switch is faulty. In the middle position the dip light is on, when I go to main beam the lights go out. If I select the 3rd position which is auto lights. every thing works correctly.
Is the switch faulty and if so how do I remove it to fit a new one
thanks for the answeri
Feb 13, 2010 at 3:48 AM
DAVE H
  • 13,383 POSTS
COMBINATION SWITCH
Removal & Installation (XJ8 & XJR)
Remove steering wheel and air bag. See STEERING WHEEL & AIR BAG . Remove 4 screws and remove driver's side undercover panel.
Release headlight/turn signal switch and wiper/washer switch wiring harness connectors from bracket and disconnect connectors. Cut tie straps, remove key transponder from wiring harness, and disconnect connector.
Disconnect cancellation module wiring harness connector. Remove 4 bolts attaching combination switch/cancellation module to steering column. Remove steering column switch assembly for access.
Remove headlight/turn signal switch from switch assembly. Release wiper/washer switch from switch assembly (soldered connections do not allow the removal of switch).
Remove cancellation module from mounting bracket. Remove wiper/washer switch, bracket, and audible warning speaker assembly from column. To install, reverse removal procedure.
Feb 24, 2010 at 2:58 AM
