1998 Jaguar XJ8 where is the altinator
JAGINONDOWN
  • 1998 JAGUAR XJ8
Electrical problem
1998 Jaguar XJ8
will you send me a pic that shows the place where the altinator is under the hood and a pic of the altinator to show the actual place to connect the possitive cable to jump off car?
Wednesday, December 9th, 2009 AT 1:28 PM
DAVE H
  • 13,384 POSTS
Removal & Installation (XJ8, XJR, XK8 & XKR)
Disconnect negative battery cable. Remove battery cover. Remove air cleaner assembly. Remove twin fan and motor assembly from behind radiator. Remove supercharger drive belt (if equipped).
Remove drive belt from generator. Using Spanner Wrench (XDHM 1415) on center bolt of belt tensioner idler pulley, turn adjuster assembly left, against spring tension. While holding tensioner against spring tension, remove drive belt from generator pulley.
Release tensioner slowly and remove spanner wrench. Remove drive belt. Raise vehicle on ramp. Remove air intake ducting from generator. Disconnect generator harness from generator. Reposition suppression module harness to clear generator.
Remove lower mounting bolt and reposition harness mounting bracket. Remove upper securing bolt and remove generator from mounting bracket, forward, toward the radiator.
To install, reverse removal procedure. Tighten lower and upper mounting bolt and nut to specifications
Tuesday, January 5th, 2010 AT 5:54 AM
