1998 Jaguar XJ8 timing
125,000 MILES • V8 • 2WD • AUTOMATIC
KEITH HILL
i had the primary timing chains and all tensioners replaced, after mechanic finished, the engine has a very bad miss at low idle.
Aug 3, 2010 at 7:46 AM
JAGTECH360
  • 74 POSTS
You have a few possibilities. Either it is not timed correctly or you have bent valves. Depending on who installed the tensioners and his/her knowledge and access to the special tools required, this could easily get messed up. If the tensioner failed whilst you were driving, it could have damaged a valve.
Oct 30, 2010 at 3:20 AM
