1998 Jaguar XJ8 Noise after belt and belt tensioner change
POOLHILL
Engine Mechanical problem
1998 Jaguar XJ8 V8 Two Wheel Drive Automatic
Jaguar XJ8 only 44000 miles. at service, belt changed,returned with terrible squel,went back changed belt tensioner,returned on cold start up best described as ratchet noise for about 10 seconds,then ok No noise on warm startup.No problems or noise prior to service.Looking closely belt may be mis aligned-would this cause noise,or is it more seriousIs this 3.2 version the ones with the inferior chain tensioners
Mar 15, 2010 at 12:10 AM
DAVE H
  • 13,383 POSTS
mis-aligned belt will cause a squeal .. also clean all pulleys
Mar 15, 2010 at 11:10 PM
POOLHILL
Thanks I will check all that
Mar 16, 2010 at 6:13 AM
