1998 Jaguar XJ8 low oil pressure indicator light in red
182,000 MILES • V8 • 2WD • AUTOMATIC
STEVEN1906
Greetings:
I'm getting a warning indicator light in red on my dast "low oil pressure." when I check the oil is fine and at the right level. the light seems to come on a random. no sounds are coming from the engine and no decline in performance. What could this be? and does it sound like a very expensive job to fix?
Aug 4, 2008 at 7:03 PM
TLEMACKS
Did you get an answer to your problem as I have the same year car with the same problem and just posted a similiar question? Thank you
Greetings:
I'm getting a warning indicator light in red on my dast "low oil pressure." when I check the oil is fine and at the right level. the light seems to come on a random. no sounds are coming from the engine and no decline in performance. What could this be? and does it sound like a very expensive job to fix?[/quote]
Sep 6, 2008 at 2:21 AM
