1998 Jaguar XJ8 Low oil pressure indicator light
95,000 MILES • V8 • 2WD • AUTOMATIC
TLEMACKS
My low pressure indicator light comes on at random after what appears the engine has warmed up to normal operating temperature. It only comes on at full stops and goes off immediately after I accelerate. It will also go off if I t put the car in neutral while sitting at a stop light. When I check the oil level it is always fine. What should I check for? Thank you for your assistance.
Sep 6, 2008 at 2:18 AM
DAVE H
  • 13,383 POSTS
start by replacing the oil pressure switch it may be faulty
Dec 31, 2009 at 1:10 AM
