1998 Jaguar XJ8 Line running from radiator
110,000 MILES • V8 • 2WD • AUTOMATIC
TALON58
The radiator on my 1998 Jaguar XJ8 have two metal lines running from it. I think they are engine cooling lines with the upper line being a male line and the lower line being a female line. I need to replace the lower line but I'm not sure of the name of the part that I need to order.
Aug 11, 2010 at 4:54 PM
  • 75,988 POSTS
You have an automatic transmission therefore you should a cooler lines going to the radiator to reduce the temperature of the transmission
Aug 11, 2010 at 9:13 PM
