I DROVE OVER A TRIANGLE SHAPED METAL PIECE THAT FITS INTO A MANHOLE COVER AND IT BENT THE PAN UNDER THE PASSENGER SEAT AND CAUSED ALL POWER TO SHUT DOWN. THE CLUSTER READOUT DISPLAYED TRANSMISSION DEFAULT WRONG PART FITTED-RESTRICTED PERFORMANCE AND THE ENGINE STARTED TO MISS. TWO DAYS LATER THE ENGINE LIGHT CAME ON AND THE TRANSMISSION IS IN LIMP MODE. CAN YOU GIVE ME ANY INFO ON HOW TO CORRECT THIS SITUATION. I THINK THAT THE PROBLEM IS IN THE COMPUTER BUT NEED A QUICK FIX IF POSSIBLE. THANKS, FLIGHTCOMMANDER@MSN.COM
Oct 2, 2010 at 2:28 AM
