Hood will not open
1998 JAGUAR XJ8
PAUL LOCOCO
Car listed above is two wheel drive with an automatic transmission.
The passenger side hood latch will not release. How can i open it? can I go through the glove box?
Oct 14, 2010 at 6:05 AM
JAGTECH360
  • 74 POSTS
You will not be able to go through the glove box. I don't exactly remember how I broke into these when I came across that problem but I'm sure its either through the fender well or from below the car.
Oct 30, 2010 at 3:22 AM
LUCK_99
Remove plastic on inside wheel well if you have it, if not look for hole or drill a hole in wheel well around location of latch and stick a screwdriver in hole pushing towards trunk and latch should release.
Dec 26, 2020 at 11:20 AM
