1998 Jaguar XJ8 CYLINDER HEAD TORQUE SPECS AND PATTERN
1998 JAGUAR XJ8
13,000 MILES • V8 • 2WD • AUTOMATIC
FABULOUS
TORQUE SPECS FOR CYLINDER HEADS AND THE PATTERN FOR TORQUE OF THE BOLTS
Jan 6, 2010 at 11:12 AM
DAVE H
  • 13,384 POSTS
Cylinder Head Bolts Step 1 (8 & 10 mm Bolts)........Hand Tight Step 2 (10 mm Bolts)............Ft.Lbs 15 N.m(20) Step 3 (10 mm Bolts)....................26 (35) Step 4 (10 mm Bolts).............Additional 90 Degrees Step 5 (10 mm Bolts).............Additional 90 Degrees Step 6 (8 mm Bolts)...................17-20 (23-27)
https://images.2carpros.com/forum/automotive_pictures/266999_jag_55.jpg
Jan 6, 2010 at 9:41 PM
