1998 Jaguar XJ8 98 xj8
NICHOLSL
Engine Performance problem
1998 Jaguar XJ8 4 cyl 59,000 miles
I was driving the car and had no problems, then I went to star it and it said engine stalled. I put a obd scanner on it the code was P1111 can give me some guideance.
Feb 13, 2009 at 5:01 PM
  • 31,937 POSTS
Hi there,
Speaking to a Jag tech, he says that not all readers will pull correct codes, and that the Jag scanner should be used, this code is often seen with after market scanners, and P1111 is not a known code, so get a Jag scan done first.
Mark (mhpautos)
Feb 13, 2009 at 9:43 PM
