1998 Jaguar XJ8
MINNIE
  • 1998 JAGUAR XJ8
Engine Mechanical problem
1998 Jaguar XJ8 V8 Two Wheel Drive Automatic
how do you change the fuel pump in a 1998 xj8 jaguar?
Saturday, June 14th, 2008 AT 11:36 AM
DAVE H
  • 13,384 POSTS
Removal & Installation
Remove fuel tank. See FUEL TANK. Disconnect evaporative breather hose. See Fig. 4. Using Lock Ring Wrench (JD174), remove locking ring from evaporative flange.
Disconnect fuel pump wiring harness connector. Using Fuel Tank Hose Clip Driver (JD175), disconnect fuel hoses from fuel pump. Remove fuel pump and pump mounting rubber from support bracket.
Remove tie wrap from pump mounting rubber. Using a twisting motion, lift and remove fuel pump. To install, reverse removal procedure. Ensure pump is fully seated in mounting bracket inside fuel tank.
Thursday, December 31st, 2009 AT 6:21 AM
