What you have described doesn't make sense but I think I know what you meant. Your engine is flooded. You need to remove the plugs, crank the engine over with the throttle depressed to the floor several times, apply a few drops of engine oil to each cylinder, crank again (always with throttle to floor or injectors disabled), install new plugs and retry starting. DO NOT CRANK FOR TOO LONG IF IT'S ATTEMPTING TO FIRE WITHOUT PUTTING PEDAL TO FLOOR. Putting throttle pedal to floor disables the injector (clear flood mode).
SPONSORED LINKS
Saturday, October 30th, 2010 AT 10:09 AM
